Question about application performance
Home › Forums › General Questions › Question about application performance
  • #36660
    soothsayer00
    Before using Verge3D I wanted to make sure everything is running smoothly, I made a demo application upload it to my WordPress site. and noticed it needs a lot of time to load. At first I thought it might be something with my model, so I uploaded some of the demo applications that are in the Verge3D applications folder, and they seem to be loading slowly as well.
    My question is what are the requirements for a basic application to run smoothly? what do I need to look for in the hosting service?
    #36667
    You might use Amazon’s CDN service to serve your content quickly (or use Verge3D Network which is powered by AWS). Otherwise, your host should have access to fast connection – at least 100Mb or more.
    #36674
    visualizer
    Hey Yuri
    Just as said by soothsayer00, I just want to again re-highlight my way back given strategic suggestion.
    Does V3D team have anything in consideration in near future regarding making the LOD type loading? ( like it will load a low poly or partial scene & then while user is seeing primary things, the further detailing will load ) youtube like streaming things or some kind?
    Today people really have less attention patience & hence such things might be helpful to consider.
    Regards
    #36685
    soothsayer00
    I was asking in terms of processing power and RAM memory of the host, because one of the demo applications that are in the verge3d applications folder is pretty small in size around 2-5MB cant remember exactly atm. And when i upload the application to my current host the loading screen takes around 1min to complete.
    #36707
    These are quire irrelevant since all the files are static and are served as is, without any processing on the server side. The connection speed and the processing power of the client’s computer are however crucial to WebGL/Verge3D performance.
