Object Animation Problems
Home Forums Graphics / 3ds Max Object Animation Problems
  • #47342
    s1960
    Hey there, I’m a verge3d newbie and try to get my first animation on the way. I´m animating an object, what just moves along one axis. What happens is in sneak preview it positioned the object on an different place and moves along the wrong axis. I set everthing right from 3ds max side (xform, reset transform). And when I export to .glb, I can’t import it in Powerpoint.
    Thanks for any suggestions
    #47377
    can you share max file?
    #47394
    s1960
    Hello Mikhail, today, after loading new my 3ds Max Software, the animation in sneak preview runs correct as it should. Maybe it was referencing to old parameters, so it shows the animation in wrong position and axis. Obviously it needs a fresh-up by loading the software new.
    The other problem is still there. When I export directly from 3ds max to .glb, I can´t load it into my Microssoft365-Powerpoint App (Version2110).
    So it does, when I export without animation keys. I had set in max the key filter just to “position”.
    Thank you for helping.
