Is it possible to change the font in the description field?
Home › Forums › Puzzles › Is it possible to change the font in the description field?
  • #42487
    tomb
    Hello Verge3D Experts!
    This is a very nice product with great tutorials! I’m testing Verge3D for Blender to generate rotatable 3D images with interactive hotspots leading to feature description fields similar to those seen in the Swiss Army Knife demonstration.
    Using that demonstration as a guide I created a file using one of our our products, and the annotations with description fields work great, but because I’m calling attention to technical specifications of each feature, I also need to change the font in the description field to bold or italic and possibly to a font with special characters. Is this possible to accomplish within Puzzles?
    Thanks so much!
    …Tom
    #42496
    Yes.
    There are many ways to do this. Depending on the complexity of the design you might be better off doing this via HTML and CSS.
    Otherwise, you can use the annotation puzzle…then insert text editor puzzle into it. Switch it from <no highlight> to HTML.
    Then enter your typical html syntax for controlling your text and you are set. This will allow you to use the base annotations with some fancier text.
    Hope this helps.
    #42505
    tomb
    Thank you Xeon! That solution works perfectly!
    …Tom
    #42516
    Fantastic…glad I could help.
