Installation issue
Home Forums General Questions Installation issue
  • #32671
    mikepflat10
    I have a Macbook Pro running Catalina and Blender 2.90.
    I have just tried to install Verge3D and have completed the first step from your User Manual. See screenshot below. Script line reads: /Users/michael/verge3d/
    However, when I re-start Blender, there is no sign of the Verge3D addon.
    I would be grateful for your help in overcoming this issue.
    #32673
    Please specify just the path to the installation folder, i.e.
    or
    /Users/michael/whatever_nested_folders/verge3d/
    From you screenshot it looks to be a different path.
    Example:
    #32676
    mikepflat10
    Hi Uri,
    Thanks. However, unfortunately, I gave you my previous screenshot.
    The correct one below also produces the same problem.
    #32682
    To be exact, the path should be as follows
    /Users/michael/verge3d_blender/
    if the installation directory was not renamed.
    After specifying the path, Blender should be restarted. Afterwards, the Verge3D addon should become searchable in the list of addons.
    #32687
    mikepflat10
    Hi Yuri,
    Thank you – I didn’t realise that I had to include the whole unzipped file from it’s root. However, I’ve tried that and it still doesn’t work.
    I’ve added screenshots of the File Path entry, the add-on search and the file structure.
    #32693
    to make sure, did you download Verge3D from the downloads page and not the standalone addon from Github?
    #32698
    mikepflat10
    Yes, I did.
    #32716
    there is a strange directory called verge3d in your verge3d_blender directory. Please delete it and check if it works.
    #32727
    mikepflat10
    Thank you so much (to both Yuri and Alexander).
    Your suggestion didn’t work at first but I then did a new download and installation and, bingo! – it worked.
    Thank you for your persistence in solving my issue. Once I’ve tested it, I hope to be buying a licence.
    #32734
    glad you worked it out! :yahoo:
