Cannot install
Home Forums General Questions Cannot install
  • #28763
    When I click the box to enable the add-on under preferences, I get this error (Blender 2.83 w/ verge3d-blender-3.2.0-pre3):
    Traceback (most recent call last):
      File "C:\Program Files\Blender Foundation\Blender 2.83\2.83\scripts\modules\addon_utils.py", line 351, in enable
        mod = __import__(module_name)
      File "C:\Users\Basquiat's Crown\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\verge3d\__init__.py", line 27
        ROOT_DIR = r'C:\Users\Basquiat's Crown\verge3d_blender'
    SyntaxError: invalid syntax
    Any help is greatly appreciated
    #28782
    most likely it relates to the apostrophe mark in your user name. We’ll try to investigate this further. Thanks for reporting!
    #28792
    I had the slightest thought that that was the case…I’ll try changing my username and let you know if it worked…many thanks!
    #28825
    I’m finding it very complex to change my username folder in Windows 10. I’d have to edit my registry, etc. and I’m not comfortable doing that as I’ve read of the possibility of messing something up.
    I can confirm that I’ve used previous versions of Verge3D with previous versions of Blender 2.8x that installed without problem.
    Hoping there is a safe obvious fix that I’ve not found.
    Many thanks
    #28826
    UPDATE: Problem solved. In c:/Users, I created a new folder without the apostrophe (c:/Users/BasquiatsCrown). I re-installed Verge3D and made sure it was installed into the new folder. I then launched Blender 2.83 and was able to enable Verge3D in the add-ons preference tab.
    Really appreciate your help Yuri. I hope this helps anyone else that has this issue.
    #28840
    glad you worked it out! we’ll try to handle this issue on our side too. :good:
