Using maxscript to export GLTF
Home Forums Graphics / 3ds Max Using maxscript to export GLTF
  • #21603
    Hello,
    I’m writing a tool inside of 3ds Max and I would like to export GLTF files using maxscript. Is this currently possible with Verge3D? I could not find anything in the help. Also, I’m running the trial and I could not find anything.
    Thanks
    -misterfriday
    #21604
    Hello again,
    I’ve found the “::v3dManager” struct. So far so good! :)
    Is it possible though to export an object using a path as a parameter?
    like:
    ::v3dManager.exportGLTF @”C:\temp\mygltf.gltf”
    Thank you
    -misterfriday
    #21622
    I think you should try using exportGLTFPath() method –
    Replace ‘path/exported_file.gltf’ by the actual path to the exported asset.
    Co-founder and CTO at Soft8Soft
    FB | Twitter | VK
You must be logged in to reply to this topic.
