set authorization header from puzzles
Home Forums General Questions set authorization header from puzzles
  • #56143
    David Bujeda
    Hello,
    I would like to know if it is possible to set the authorization header from the puzzles when using send data. As per now, I’m saving the puzzle and hardcoding in the visual_logic.js after that.
    // sendData puzzle
    function sendData(data, url, callback) {
    var req = new XMLHttpRequest();
    req.onreadystatechange = function() {
    if (req.readyState == 4 && req.status == 200) {
    if (req.getResponseHeader(‘Content-Type’).indexOf(‘application/json’) > -1)
    _pGlob.loadedFile = JSON.parse(req.responseText);
    else
    _pGlob.loadedFile = req.responseText;
    callback();
    req.open(‘POST’, url, true);
    if (typeof data == ‘string’) {
    req.setRequestHeader(‘Content-type’, ‘text/plain’);
    } else {
    // serialize to json
    req.setRequestHeader(‘Content-type’, ‘application/json’);
    data = JSON.stringify(data);
    req.setRequestHeader(‘Authorization’, ‘xxxxxxx’);
    req.send(data);
    you could possibly employ the exec script puzzle for adding custom code. This would save you from repeatedly editing of freshly generated visual_logic.js.
    https://www.soft8soft.com/docs/manual/en/puzzles/Advanced.html#exec_script
