- This topic has 27 replies, 5 voices, and was last updated 1 year, 5 months ago by
David Duperron.
2022-12-25 at 4:44 pm #59227
ParticipantA measuring system for Verge3D.
Get it on Gumroad
2022-12-26 at 6:04 am #59236
Yuri KovelenovStaff2023-01-01 at 4:43 pm #59322amirferdos
it was great!2023-10-16 at 6:18 am #67634baz.schonfeldt
CustomerThis is great. However, I see in the example that you are only able to click on the room. Is it possible to measure the distance between the TV unit and the wall to the left for example?
2023-10-16 at 6:34 am #67636kdv
ParticipantPossble if you add TV or any other mesh to the list of objects to be measured. In that demo only walls and floor are in the list.
Or you can click on the wall near TV to get the distance…
2023-10-16 at 6:58 am #67638baz.schonfeldt
CustomerI have a complex scene with many objects. How can I get trial access to the plugin to see if it does what I need?
2023-10-16 at 7:29 am #67644kdv
ParticipantHow can I get trial access
Have no idea
Visually it does only two things:
1) draws points on specified objects and a line between the points.
2) calculates the distance between the points and draws the value on a label.
Nothing else.Puzzles and JS coding. Fast and expensive.
2023-10-29 at 1:10 pm #68033baz.schonfeldt
CustomerSo I paid and got this plugin. I have set it up but I can’t get it to work. I use the ‘enable measuring tool’ puzzle and add the objects I want to measure to the list but when I hover over them my cursor changes to a circle with a line through it and the tool doesn’t work. I don’t see any documentation, is there something else I need to do?
2023-10-29 at 1:26 pm #68035kdv
ParticipantShow your puzzles.
2023-10-29 at 1:31 pm #68036baz.schonfeldt
CustomerSee attached. The referenced element is a checkbox in the html
2023-10-29 at 1:40 pm #68038kdv
ParticipantUmmm… Very interesting logic. Espesially all colors beeing red…
Replace
all objectswith this set of puzzles:
Only meshes can be measured, only meshes have geometry.
2023-10-29 at 1:52 pm #68040baz.schonfeldt
Customer…Still no joy. I’ve also added the “show all measurements” puzzle but still nothing
2023-10-29 at 1:55 pm #68042kdv
ParticipantShow the console log.
2023-10-29 at 1:58 pm #68043baz.schonfeldt
Customer…your wish is my command..
2023-10-29 at 2:00 pm #68045kdv
ParticipantNow open readme.txt and read the text inside.
