Home › Forums › Graphics / Blender › Camera Puzzles Tutorial – Empty Follows Mouse Object
- This topic has 13 replies, 3 voices, and was last updated 1 year, 12 months ago by
kdv.
2022-02-25 at 6:12 am #49605
ma77hew
ParticipantI am following the tutorial shared here on Verge3D Camera/Lights page:
https://www.soft8soft.com/docs/manual/en/puzzles/Camera.html
In the following example, an object looks at the mouse cursor. This can be achived by mapping the position of an empty/dummy object to mouse cursor with some simple math.
In order to setup such behavior in 3ds Max, make your object follow a dummy object by utilizing the Rotation Controllers / LookAt Constraint. In Blender, this corresponds to the TrackTo constraint.
I have followed these instructions and the result works as expected but the animations extremely fast. How can I slow down this camera movement? Or make it less sensitive?
– I’ve tried playing with the values
– I’ve tried unticking “inverted” for the mouse option. This seems to slow it down.2022-02-27 at 6:17 pm #49722ma77hew
ParticipantAny advice on this?
2022-02-28 at 5:03 am #49725ma77hew
ParticipantI can’t seem to get this to behave in a consistent fashion. Now, it seems the orbit moves much more slowly. Here is my setup on Puzzles and my camera setup on Blender.
I am following your tutorial directions.
Please help me figure this out.
2023-08-31 at 7:49 pm #66548
Pavel KotovStaffHey I know it is super late but I had similar problem and that’s how I solved it:
https://v3d.net/nf1
https://www.youtube.com/@Contret
https://x.com/_Contret
https://www.behance.net/Contret
https://www.artstation.com/contret
https://vimeo.com/user1750839462023-08-31 at 8:02 pm #66553kdv
ParticipantEvery frame?
It’s enough to use “on mousemove”…
https://v3d.net/bddPuzzles and JS coding. Fast and expensive.
2023-08-31 at 9:33 pm #66562
Pavel KotovStaffTried it, works well, thanks! Haven’t thought of it yet
https://v3d.net/nf1
https://vimeo.com/user1750839462023-11-28 at 3:13 am #68821ma77hew
ParticipantNever got this to work for me, even after following these instructions. Can you provide you show me your project and puzzle?
2023-11-28 at 4:07 pm #68854ma77hew
ParticipantDoes anyone have a working example of this? it’s on the Verge3D official documentation and yet I still have not seen it working ever
2023-11-28 at 10:41 pm #68878kdv
ParticipantPuzzles and JS coding. Fast and expensive.
2023-11-29 at 9:12 pm #68894ma77hew
ParticipantThank you for your help @kdv. Other users should know additionally to check this option to achieve the interaction as stated.
You are using Orbit as a camera control? How can we use First Person?
2023-11-29 at 9:53 pm #68895kdv
ParticipantHow can we use First Person?
The same way. But it’s next to senseless. And you can’t use it if the pointer is locked.
2023-11-29 at 9:59 pm #68896ma77hew
ParticipantI actually switched to try but it seems this disables the AWSD keys. I am looking into solving this right now
2023-11-30 at 6:38 pm #68918ma77hew
ParticipantIs it possible to avoid making users press Escape key on Pointerlock?
2023-12-01 at 5:46 am #68921kdv
ParticipantNo.
