Home › Forums › General Questions › AR toturial
- This topic has 28 replies, 6 voices, and was last updated 6 months, 3 weeks ago by
alpaslan.
2024-06-11 at 9:03 am #74665
safago
ParticipantHello all,
am working on an online store using woocommerce and am using verge3d for the products i manage to configer the products variations fine but i cant activate the AR find as some of my products should be on the ceeling and others will be on the wall and i cant figer it out.
i need some help please.Thanks
2024-06-11 at 9:43 am #74666kdv
ParticipantFirst of all, run the official AR demo from the App Store and try to position the farmer model on walls and ceiling.
2024-06-11 at 9:47 am #74667safago
Participanti did this but i couldnt position hims on ceiling or walls he is alwys on the floor?
2024-06-11 at 11:01 am #74668kdv
Participantbut i couldnt position hims on ceiling or walls
The same will be with your models. In theory it’s possible, but in practice it works properly only with horizontal surfaces facing upward
2024-06-11 at 12:00 pm #74743safago
Participanti cant find anyone to support, do you know someone that i can pay him to help?
2024-06-12 at 4:19 pm #74757xeon
CustomerAs KDV has stated, V3D native AR is best suited for things on the floor or horizontal surface.
If you have the resources (tech and financial) to build native AR apps you would have a better chance to an elegant solution that provides the ability to recognize non horizontal Z up surfaces and orientations more accurately.
Using V3D you could still place objects on the ceiling by placing the origin point of the object in your scene on the floor and the object above it by 8 feet or so…and providing a positioning tool within your app to allow the user to raise or lower the object. Clunky but dooable. Not a great user experience but simple.
Tutorials - https://www.xeons3dlab.com2024-06-12 at 4:32 pm #74758kdv
ParticipantIt’s possible to detect walls (without any additional logic), but it significantly depends on walls textures and lighting ))) Some walls are detected, some are not. Chances are 50/50. Nobody will agree to work with such an unstable feature.
2024-06-12 at 10:03 pm #74766xeon
CustomerNot to mention the Z up orientation should change when detecting a wall….but totally agree not usable.
Tutorials - https://www.xeons3dlab.com2024-06-14 at 8:05 am #74851visualizer
CustomerI guess Verge 3D team shall provide couple of more AR samples and couple of standard tutorials for setting up AR scene.
There is only one example of a farmer boy so far I have seen.2024-06-17 at 9:23 am #74908safago
ParticipantYes i agree 100% and also tutorials to explain how things are done.
2024-06-18 at 12:16 pm #74930safago
ParticipantHey guys,
In the farmer model when you activate ar it opens an option for edit location and size, i can’t find anything in the puzzle logic about can anyone advice?2024-06-18 at 1:17 pm #74935visualizer
CustomerHere is a set of puzzles about the location (position) of that cartoon boy.
however I think it carries a same model scale as blenderAttachments:
2024-06-19 at 12:22 pm #75027safago
ParticipantThanks bro nut i cant understand it if you can send me a working file to understand it please do.
Thanks in advanced2024-06-20 at 10:30 am #75086Francesco Sorrentino
CustomerMost augmented reality systems use images as markers as references for anchoring objects. Would such a solution be conceivable with Verge 3D?
2024-06-20 at 10:42 am #75087visualizer
True that’s what I recently tried to convey to Verge team already. This thing is going to add much value to Verge’s capabilities for many users.
Yuri has responded to look in to it.you may refer to this thread –
https://www.soft8soft.com/topic/verge-ar-query/ -
