UV's prevent export !Solved!
Home Forums Bug Reports and Feature Requests UV's prevent export !Solved!
  • #15490
    ptcreative
    using Blender 2.8 25/05 Verge3D Version 2.12.5
    issue – none of my exiting models are able to be exported as Verge3D .gltf or to Sneak Peak unless I delete UV’s.Screenshot of the error attached and .blend
    I’ve tried exporting directly as well as appending then exporting. thanks
    EDIT: Turns out using it works fine with the latest build of Blender
    ptcreative
    upon testing another object, UV’s don’t cause the error but now auto smooth normals cause the same error.
    #15496
    This issue should be fixed in the latest Blender 2.80 build. Please update Blender and see if it works for you.
