Home › Forums › Official Announcements › Verge3D 4.9 pre1 available!
- This topic has 23 replies, 9 voices, and was last updated 4 months ago by
c4cc.
2025-01-16 at 11:42 am #79884
Yuri Kovelenov
StaffWe are excited to announce Verge3D 4.9 and present its first preview for public testing! Features included:
☞ Direct export from Blender, 3ds Max, or Maya to standalone HTML file
☞ Auto sliding around an obstacle in first person mode
☞ Faster export of long animations
☞ Supported 3 new Arnold nodes for 3ds Max and Maya
☞ Optimizations to overcome the CPU bottleneck for huge scenes
☞ More robust WordPress plugin
☞ Fixed bugs!More details below:
2025-01-16 at 11:42 am #79885Yuri Kovelenov
StaffExport to HTML
You can now squeeze a Blender, 3ds Max, or Maya scene into HTML format. The resulting standalone
.html
file bundles the engine, meshes, and textures together. Unlike with the standard Verge3D app that requires a local server or uploading to a website, it can be opened like a regular file on any computer or device equipped with a web browser.Blender:
3ds Max:
Maya:
It is indeed a cool feature, however we don’t recommend using it in a normal production process. HTML is not a very efficient format for packing things into it, and there is no Puzzles, physics, texture compression, dynamic text and so on – basically it works like Sneak Peek. Still it can be a convenient way to share some 3D interactives with your colleagues or clients.
Overcoming Obstacles
We improved the first person controls significantly by implementing automatic sliding along a wall or around an obstacle. This prevents the user from getting stuck, resulting in a much smoother experience, especially on mobile where you can move only forward (no strafing controls).
Here are the links to the updated First Person demo and the old demo – just feel the difference!
We also fixed the bug when the initial direction of the camera did not correspond to what is set in the modeling tool.
Blender Integration
We optimized export of multiple and/or long animations. On rusty occasions the export is performed up to 10 times faster.
We fixed the Reroute node not working properly in Verge3D in some cases. Thanks for reporting this on the forums.
We fixed the Clamp option of the Map Range node exported incorrectly. Thanks for reporting this on the forums.
3ds Max Integration
Besides the usual Verge3D menu, you can now use the standard Export menu for exporting, where you can select Verge3D glTF from the list.
You can now use 3 more Arnold-based nodes in your shaders: Uv Projection, Matrix Transform, and Triplanar.
We supported filtering and wrapping options for the Arnold-based Image node.
Maya Integration
We supported exporting only selected objects using File > Export Selection. (The nearby option File > Export All has always worked.)
Finally, we fixed the bug when ambient lights did not show up in Puzzles.
More Optimization
We continued our optimization efforts with this update. This time we focused on reducing the CPU load. For big scenes (like 1000+ separately rendered objects) it is the CPU that turns out to be the bottleneck, causing slow rendering even on powerful graphics cards.
So we addressed this problem by reviewing and reworking several aspects in the engine, such as preparing materials for rendering, updating transformation matrices, reflections and SSR calculations, and even the commonly used object selector puzzle. As a result, we managed to double the FPS in some of our tests!
Linuxoids Heads Up
Verge3D tool chain now relies on the newest Python 3.13 particularly found on Fedora 41. Minimal supported version of Python now is 3.8, so be sure to update it if necessary.
This also affects Maya 2022 on macOS which only has Python 3.7 on board, but this Maya version will soon be dropped in the ongoing life cycle anyway.
Other Improvements
Verge3D-specific setting Fit to Camera Edge now allows for negative values for its Fit Offset (available for camera-parented objects). This spares you the need to use extra empties/dummies to shift your objects outside the screen edges.
Blender:
3ds Max:
Maya:
Verge3D WordPress plugin can now handle filenames starting with dot (that is, hidden files on macOS and Linux). Particularly, the dreaded
.DS_Store
file won’t break your WordPress uploads anymore. We also fixed a potential security issue in the plugin.We made texting of messages and errors in the App Manager UI more clear and descriptive.
Bugs
We fixed freezing of the App Manager when opening
.blend
files under ChromeOS.We fixed the regression with multiple exec script puzzles in a same scenario.
We fixed the crash in VR mode when using order-independent transparency. This affected our demo Virtual Reality which now works properly. Thanks for bringing this up this on the forums.
2025-01-16 at 11:42 am #79886Yuri Kovelenov
Staff2025-01-16 at 12:33 pm #79887Pandern
CustomerAwesome! Those three maya nodes are highly useful!
2025-01-16 at 4:51 pm #79890NaxosCG
CustomerHello there, best wishes for 2025 !
The html thing… does it mean that we could use a Verge3D app locally, without any wifi / 4G connexion ?
Also, do you plan to explain / make a tutorial for the 3 new 3dsmax’ nodes ?
Best regards.
2025-01-17 at 5:31 am #79891visualizer
CustomerHey
Its exciting to see the sliding feature in first person mode.#
A little thing to mention, can you include the feature like1. Crouching or stooping or crawling with some key hit
2. Jumping on space bar hit or somethingIt will make the experience as a complete thing I believe.
2025-01-17 at 6:52 am #79892Yuri Kovelenov
Staff@Pandern Glad you like it!
yep!
See the Verge3D for 3ds Max docs included with the distribution. Will publish them online once the stable release it out.
Jumping on space bar hit or somethingFor more advanced features we suggest using the physic engine like we did in the Snowballs demo. It is difficult to implement those with physics.
2025-01-20 at 8:35 am #79906visualizer
CustomerOh I see.
Noted the point thx !2025-01-20 at 9:39 am #79909NaxosCG
Customerdoes it mean that we could use a Verge3D app locally, without any wifi / 4G connexion ?
yep!
Ok great ! what about the puzzles then ?
Can we export as usual, creat puzzles, then back to max, export as html and the app will act as espected ?"1+1=3... for large values of 1"
2025-01-20 at 11:10 am #79910Yuri Kovelenov
Staffwhat about the puzzles then ?
Nope Puzzles aren’t supported with HTML export – it only supports what is included with the glTF file (works similarly to Sneak Peek). So no interactivity beyond Orbit / First Person camera controls.
2025-01-20 at 1:19 pm #79912NaxosCG
Customerwhat about the puzzles then ?
Ok, i get it and understand why. Next step is to make magic happend, and export html using puzzles made earlier
That and the online rendering / openGL pathtracer, of course
2025-01-20 at 1:48 pm #79913domjasper
CustomerAwesome. Always love to see new updates. Great job guys!
2025-01-20 at 6:46 pm #79920NaxosCG
CustomerAt least the AR system would be a usefull point to get from 3dsmax without wifi / server
2025-02-06 at 1:11 pm #80088Thomas Fabini
CustomerHi Yuri,
That specific line gives me that tingly warm and fuzzy feeling
Since we can’t use the first person mode in VR and much more customization is usually required – would you care to elaborate (if possible) on the mechanics you used for the drift along obstacles? If that’s something which could be roughly build with puzzles, the type of navigation used in the VR Demo would greatly benefit from this.
Do you calculate the drift from that simple, flat floor mesh or does it require raycasting toward vertical walls to get the normals and calculate the drift angle?
2025-02-07 at 6:32 am #80105Alexander Kovelenov
StaffIf that’s something which could be roughly build with puzzles, the type of navigation used in the VR Demo would greatly benefit from this.
Hi Thomas,
Here is how we do it. You can use this snippet as a basis for your own puzzle or with “exec script”:_handleCollisions() { if (!this._enableCollisions || this.collisionMeshes.length == 0) return; this._raycaster.ray.origin.copy(this.object.position); this._raycaster.far = this.storyHeight; const intersections = this._raycaster.intersectObjects(this.collisionMeshes, false); if (intersections.length > 0) { const intersection = intersections[0]; this.object.position.y = intersection.point.y + this.gazeLevel; this._onCollisionMesh = true; } else if (this._onCollisionMesh) { let minDistance = Infinity; for (const mesh of this.collisionMeshes) { if (!mesh.geometry.boundsTree) { console.warn('v3d.FirstPersonControls: no bounding tree found on ' + mesh.name); continue; } this._toMeshSpaceMatrix.copy(mesh.matrixWorld).invert(); this._lastIntersection.copy(this.object.position); this._lastIntersection.y -= this.gazeLevel; this._lastIntersection.applyMatrix4(this._toMeshSpaceMatrix); const target = this._ppTarget; mesh.geometry.boundsTree.closestPointToPoint(this._lastIntersection, target); if (target.distance < minDistance) { this._nearestPoint.copy(target.point); this._nearestPoint.applyMatrix4(mesh.matrixWorld); minDistance = target.distance; } } if (isFinite(minDistance)) { this.object.position.copy(this._nearestPoint); this.object.position.y += this.gazeLevel; } else { // NOTE: fallback if no bounding trees present on collision meshes this.object.position.copy(this._lastPosition); } } }
This new code is from Verge3D preview that uses closestPointToPoint() method to push the camera back to the collision map. You’ll need to modify it to handle the “camera control object” instead.
