Home › Forums › General Questions › Select objects in a way other than a drop-down selector?
- This topic has 9 replies, 3 voices, and was last updated 5 years, 9 months ago by
Yearning for the future.
2020-05-29 at 3:46 am #28143
CustomerHello!everyone!
In a recent experimental project, I tried to select groups in the scene with the Numbers in the variables.I’ve changed the names of these groups to specific Numbers.How can I do this in a puzzle?
:) :) :)2020-05-29 at 3:59 am #28145Yearning for the future
CustomerI’ve seen other topics that say you can do this using text puzzles. How do this? :)
2020-05-29 at 4:41 am #28152
GLiFTeKCustomerUse a just a blank text puzzle piece and type the name of the object. Or use a variable that equals that object. You don’t need to use the “create text” puzzle, unless you’re creating the name dynamically.
plz share Discord link & on your signature!2020-05-29 at 5:46 am #28154Yearning for the future
CustomerDo you mean adding variables directly?I’m sure the value of the variable is the same as a set name of blender, but it doesn’t seem to work…
2020-05-29 at 5:54 am #28158Yearning for the future
CustomerI don’t want to change the name, I just want to show the collection of the corresponding name according to the value of the variable!
2020-05-30 at 10:12 am #28187Yearning for the future
CustomerCan someone help me?Although I have found alternatives, it is clear that the puzzle pieces are not as simple and convenient as the one I wanted! :) :)
2020-05-30 at 11:14 am #28203
Yuri KovelenovStaffI just want to show the collection of the corresponding name according to the value of the variable!
why don’t you use the variable directly?
2020-06-01 at 1:00 am #28280Yearning for the future
CustomerOh, thank you, yuri!Thanks for your solution!
But I ran into a new problem: the bloom effect failed when the background was transparent!2020-06-01 at 10:16 pm #28298
GLiFTeKCustomerAre those icon images square polygons using .PNGs with alpha blend?
plz share Discord link & on your signature!2020-06-08 at 8:03 am #28523Yearning for the future
CustomerYes, I didn’t use HTML elements to make ICONS!
I think, maybe you inspired me, maybe I should use HTML + CSS to make ICONS look better! -
