The ip address could not be found. an error called
Home Forums General Questions The ip address could not be found. an error called
Viewing 14 posts - 1 through 14 (of 14 total)
  • #60641
    sfwq
    #60648
    The external server is accessable only within your local network by it’s local IP adress 192.168.*.*.
    #60653
    but someone else says I can’t find my IP address
    Where this “someone” is located? In your flat or in another town? )))
    #60659
    The external server interface affects the access from your local network only. By default the link to you app looks as follows http://localhost:8668/your_app/your_app.html and you can open it only from the PC where Verge3D is installed. Activating the external interface allows to access apps from your local network (to test on phones via Wi-Fi, for example).
    But it doesn’t mean that anybody can access now your apps on your PC. They are accessable only inside your local network.
    What IP adress your “somebody” enters in his browser? Did you use port-forwarding? Is this “somebody” trying to load the app from your local PC or the app is already uploaded somewhere else?
    #60667
    sfwq
    I exported the vege3d project and attached the embed to the website.
    The first time was fine, but now the client is not able to access the site and see the exported verge3d project.
    But when I access the site, there is no problem.
    When a client enters the site and accesses the page to which the verge3d project is attached, it says that the ip address cannot be found.
    #60669
    Please make sure the embedding URL contains a valid domain such as your_client_site.com, and not something like 192.168.1.4 which is only accessible by you.
    can you share this URL for us to test it out?
    #60670
    sfwq
    I checked the embedding and it says link deleted
    can i change this to my client site url?
    #60671
    sfwq
    link deleted
    This is the url written in the embedding.
    Can I replace this with the url I specified that is not v3d?
    #60672
    In ideal you should replace the iframe src with a-section.html and upload your app to the same server and the same folder where the main (parent) page is located. It’s a bad idea to use cross-domain iframes.
    #60697
    sfwq
    sfwq
    I exported the verge3d project and attached the embedding to the page.
    #60702
    link deleted
    Your app is working. No errors concerning IP adress.
    You’d better add a couple of attributes in the <iframe> tag to remove the vertical scroll bar. frameborder="0" and style="position: fixed;"
    There is a problem when entering the full-screen mode
    And you will have more problems if you plan to use puzzles’ logic and continue to use the cross-origin iframe
    #60715
    sfwq
    #60718
    Yeap, the page is accessable, the app is working. The same issues as with the previous page.
    Ask your client to ping v3d.net and cdn.soft8soft.com
