Export jpeg from GLTF?
Home Forums General Questions Export jpeg from GLTF?
  • #33998
    michalex19
    I know there is an option to export jpeg for textures with the normal Blender export GLTF, is it possible to export V3d with Jpegs? If not, could I use the regular Blender GLTF export with Jpeg option instead of the V3d gltf export? and just make sure the textures go to the root folder? If not, is there another way to quickly replace the pngs with jpegs (without attaching them to the model)?
    Thanks in advance!
    #34004
    Verge3D glTF export takes images in their original format. So if you want them all to be jpg, then you can use some conversion script or convert them to png manually. After conversion it is necessary to reattach the images back to the materials since the file name is changed.
    You can also try to use Blender’s native glTF exporter with Verge3D. See more details here (scroll down to “Vanilla glTF Files”)
