- This topic has 81 replies, 13 voices, and was last updated 2 months, 1 week ago by
kdv.
2024-02-03 at 11:43 pm #70117
jojopellerin
CustomerHi kdv,
I have been using your plugin for IOS for quite some time and it works great.
It might be off topic since it is IOS related, but I can’t use the AR on Android. I mean even the Augmented reality demo app from verge3d doesn’t work (it says my device is not comptabile but is a recent samsumg) or doesn’t do anything.
Have you developed a plugin for android by any chance ? Would be happy to buy it as long as I can export my object (only static mesh, no animation needed).
Thank you
JordaneAttachments:
2024-02-03 at 11:58 pm #70119kdv
ParticipantAndroid OS doesn’t require any additional plugins for AR.
At least you should install
AR Core
from the Market (if your device supports it. if not, WebXR-based AR mode won’t work on your phone).Puzzles and JS coding. Fast and expensive.
2024-02-06 at 8:33 pm #70153jojopellerin
CustomerThanks for your answer.
I took the time to check on different Android Phones with AR core downloaded and I still have the same issue. All the phone I have tried are able to do AR but it doesn’t work for verge3d AR.
When I activate from my app, it asks me the authorization to make a 3D scan of my environment + position of my camera but then nothing happen. I try to click again and nothing happenI have even tried with verge3D augmented reality demo with the farmer and I have the same issue !
With Iphone no issue at all..
Any suggestion ?
Thank youAttachments:
2024-02-07 at 6:21 am #70168Yuri Kovelenov
Staff2024-02-07 at 7:59 am #70170kdv
ParticipantAll the phone I have tried are able to do AR but it doesn’t work for verge3d AR
And all of them were Samsung phones?
2024-02-07 at 3:19 pm #70201jojopellerin
CustomerThanks for your reply.
@Yuri : You are right, it doesn’t work only when using Samsung internet browser. It either freeze my phone or nothing happen. I guess I can ask my client to notify his users to only use chrome or safari.Since the AR functionality is working, I have noticed that am still far from the Farmer demo result.. The background is black and it doesn’t even try to scan the ground.
I have tried to follow each step, have I missed something ?Here is my app :
https://sub.bycharlot-figurativelabs.xyz/fabuleuse/Thank you !
2024-02-07 at 4:01 pm #70204kdv
Participanthave I missed something ?
You didn’t enable the
transparent backgroud
option on the Init tab.Puzzles and JS coding. Fast and expensive.
2024-02-08 at 11:50 pm #70314jojopellerin
CustomerHi Kdv,
That’s right.! I missed this option
Now, I am getting very close to get it down.. One last thing that hold me back, may I ask you why my “Plant” (which is an empty of several object) appear where my phone is ? It appears instantly (floating in the air) and not on the target when I click on it.
Thank you2024-02-09 at 8:57 am #70334kdv
ParticipantMost likely the origin of your plant (or the origin on its parent object) is not at the bottom of the pot.
2024-02-09 at 11:05 am #70335jojopellerin
CustomerI checked that. The origin is good (see my blender viewport SC). Also, when it exports my USDZ, it is centered.
The issue here, is that the plant appears instantly (right after the camera turn into AR mode) at the location of the phone itself. While the plant remains floating in the air at the same spot, I can start to swipe the floor and then my “indicator_invis_plane” appears as it should be.
Also, even if I click on the “indicator_invis_plane”, the plant stay at the same location. Basically nothing happen.
2024-02-09 at 11:23 am #70340kdv
ParticipantNothing to say more without the app itself. You did some mistake (maybe in puzzles, maybe in Blender) and without files it’s difficult to figure out what’s wrong. And it’s not a good idea to discuss AR for Android in the topic about AR for iOS…
2024-02-09 at 11:27 am #70341jojopellerin
CustomerI understand, makes sense.
Thanks for your feed back.2024-05-16 at 2:13 pm #74259ps
ParticipantHi kdv,
Does this plugin support UI buttons inside AR Quick Look, so that features such as annotations can be toggled. I can load a 3D model using the AR puzzle and I need support for buttons and annotations. Please let me know.
Thanks.
2024-05-16 at 3:06 pm #74262kdv
ParticipantNo.
2024-09-04 at 11:00 am #77202pimmartens
ParticipantHi kdv,
We’re experiencing some issues with the plugin in combination with Verge 4.7.1. Will there be a update in the plugin?
Thanks in advance!
