Problem : I want only to rotate the camera on mobil but it is also a click event
Home Forums General Questions Problem : I want only to rotate the camera on mobil but it is also a click event
  • This topic has 1 reply, 2 voices, and was last updated 4 years ago by xeon.
  • #42595
    Jakob Kolmanic
    Hello,
    I have a question regarding interaction with a mobile device. I have a camera that can rotate around a fixed point and several objects that can be clicked. My problem is that when I rotate the camera on the mobile device with one finger, it often happens that by rotating with the one finger also unintentionally clicks on an object and activates it.
    Does anyone here maybe have the same problem or know a solution for it?
    Thanks a lot!!!
    #42624
    Hi there,
    I have run into similar issues when the scene is filled with clickable objects. When it becomes problematic I enable double click/tap in the optional onclick.
    Alternatively if thats not practical…you can create some logic around the cameras movement.
    Basically if camera is moving ignore clicks.
    The real trick is discriminating a starting click vs a click on the object. For this I just add a short-timer to the onlick and validate the camera did not move during that small time. If the camera is in the same position…then continue with the onclick functions.
