Object doesnt look smooth
Home Forums General Questions Object doesnt look smooth
  • #59512
    krazy4
    Can anyone tell me why my objects aren’t looking smooth in verge3d interface? check attached model. Also if anyone can help me build material like attached photo, would be really helpful
    #59515
    Any chance you can provide higher res images….these are really small and very difficult to make out detail of the model.
    What application are you using to model?
    #59522
    krazy4
    here I’m attaching the model in case you could help build material as well
    If you could export as fbx…I can give it a shot.
    #59561
    You need to connect bumpnode to a texture with lines or better create a normal map and increase ruoughness.
