animated bezier curve bevel
Home Forums General Questions animated bezier curve bevel
  • #19015
    Crunch
    I animated the Bevel End property of bezier curve (effect: a growing noodle) i was hoping that would register as an animation i could control in Verge. Doesn’t seem to work. Any tips/tricks to accomplish this?
    Is it possible to use javascript to programmatically control these properties in verge? ie, change the bevel end / bevel start with code? If yes, a sample piece of code would be nice :yes:
    #19020
    Unfortunately, the animation of such params is not supported for performance reasons. You, however, may use shape key animation for changing geometry in run time.
