An issue with mobile view
Home Forums General Questions An issue with mobile view
  • #42018
    poly3d
    Hi, I’m new to Verge so I’m still checking things out and I noticed that on mobile everything looks a bit blurry or down resed, I also checked this with a few of the demo apps and on different smartphones just to make sure and it’s still not sharp, is there a setting to fix this?
    #42054
    bennesky
    You can apply “set screen scale” on puzzles, increase value will increase sharpness, 1 is default 2 is high, i use 1.5 balance between sharpness n performance. You can try yourself..
    poly3d
    It works, thank you!
