Installing multiple versions of Verge3D side by side
Then run the App Manager again from the modelling suite version that you need. Confirm version buy looking into the same About dialog.
verge3d-blender-4.12.0.exe /S
./setupAddon.py
setupAddon.bat install 5.1
./setupAddon.py install 5.1
regPlugPath.bat install 2027
./install.py
install.bat install 2027
./install.py install 2027
See here for instructions.
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
Host TCP Port Notes
Running Verge3D offline
Distributions of Verge3D
Accessing docs offline
