Installing multiple versions of Verge3D side by side
Then run the App Manager again from the modelling suite version that you need.
For example, say you installed Verge3D 4.12 for Blender 4.5 LTS and Verge3D 4.13 for Blender 5.2 LTS. To use 4.12 open Blender 4.5 and run the App Manager. To switch to 4.13, stop the App Manager via About dialog, then go to Blender 5.2, then run App Manager again.
verge3d-blender-4.12.0.exe /S
./setupAddon.py
setupAddon.bat install 5.1
./setupAddon.py install 5.1
regPlugPath.bat install 2027
./install.py
install.bat install 2027
./install.py install 2027
See here for instructions.
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
Host TCP Port Notes
Running Verge3D offline
Distributions of Verge3D
Accessing docs offline
