Known Verge3D Limitations
Revision as of 10:54, 13 December 2025 by Alexander (talk | contribs) (Verge3D for 3ds Max limitations)
This page describes common Verge3D limitations and bugs and provides possible workarounds.
General limitations
Camera Scaling
HiDPI Compositing Limitations
Export multiple animation clips for the same object
Deep Collection Instancing
Material animation
Physics
Postprocessing
Rotation animation
Textures
XRef Objects
OCIO color management mode
As of version 2025, 3ds Max uses the OCIO color management mode by default (with ACEScg color space). This system is not supported in Verge3D, since it requires more powerful GPUs and not quite feasible for the real-time browser rendering. For consistent look change color management mode to Gamma Workflow. See here for more info.
Verge3D for Maya limitations
View Transform
Always switch to sRGB gamma view transform to get consistent results. See here for more info.
