This page provides some tips for system administrators deploying Verge3D in corporate IT environments, digital media agencies, or educational institutions.
verge3d-blender-4.10.0.exe /S
python3 setupAddon.py
python3 install.py
See here for instructions.
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
Host | TCP Port | Notes |
cdn.soft8soft.com | 443 | Verge3D Asset Store, Verge3D Network CDN, Electron.js binaries |
v3d.net | 443 | Verge3D link shortener |
Running Verge3D offline
Distributions of Verge3D
Accessing docs offline
