If you happen to have many workstations and need some method for automated installation (e.g. via script), you follow do the following.
Say you need to install Verge3D for Blender version 4.10.0. First, go the folder where installation distro located, then run this command:
verge3d-blender-4.10.0.exe /S
Say you need to install Verge3D for Maya version 4.10.0. First, go the folder where installation distro located, then run this command:
This command will install into user-owned home folder, into Applications sub-folder.
python3 setupAddon.py
python3 install.py
See here for instructions.
To active Verge3D via command line, send the POST request to the running App Manager server, e.g. via cURL:
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
| Host | TCP Port | Notes |
Offline operation
Distros
Documentation
Demos
Electron binaries
Follow this guide.
