verge3d-blender-4.9.2.exe /S
python3 setupAddon.py
python3 install.py
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
Host TCP Port Notes
Offline operation
Distros
Documentation
Demos
the corresponding ZIP archive for that demo is available for download under:
Electron binaries
Follow this guide.
