verge3d-blender-4.10.0.exe /S
./setupAddon.py
regPlugPath.bat install 2027
./install.py
Both scripts support passing specific Maya version for which the plugin should be installed:
See here for instructions.
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
| Host | TCP Port | Notes |
Running Verge3D offline
Distributions of Verge3D
Accessing docs offline
