verge3d-blender-4.10.0.exe /S
./setupAddon.py
python3 install.py
See here for instructions.
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
Host TCP Port Notes
Running Verge3D offline
Distributions of Verge3D
Accessing docs offline
