verge3d-blender-4.10.0.exe /S
python3 setupAddon.py
python3 install.py
See here for instructions.
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
| Host | TCP Port | Notes |
Running Verge3D offline
Distributions of Verge3D
Documentation
Demos
Electron binaries
Follow this guide.
