verge3d-blender-4.9.2.exe /S
python3 setupAddon.py
python3 install.py
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
| Host | TCP Port | Notes |
Offline operation
Distros
Documentation
Demos
Electron binaries
Follow this guide.
