verge3d-blender-4.10.0.exe /S
./setupAddon.py
regPlugPath.bat install 2027
./install.py
See here for instructions.
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
| Host | TCP Port | Notes |
Starting from Verge3D 4.12 you can assign a proxy server right in the App Manager settings.
Running Verge3D offline
Distributions of Verge3D
Accessing docs offline
