verge3d-blender-4.9.2.exe /S
python3 setupAddon.py
python3 install.py
See here for instructions.
To active Verge3D via command line, send the POST request to the running App Manager server, e.g. via cURL:
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
Host | TCP Port | Notes |
cdn.soft8soft.com | 443 | Verge3D Asset Store, Verge3D Network CDN, Electron binaries |
v3d.net | 443 | Verge3D link shortener |
Offline operation
Distros
Documentation
Demos
Electron binaries
Follow this guide.
