verge3d-blender-4.9.2.exe /S
python3 setupAddon.py
python3 install.py
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
| Host | TCP Port | Notes |
Offline operation
Distros
These can be freely downloaded by direct links and shared on local network or via USB flash drive. No internet connection is needed for license activation.
Documentation
Demos
To find where this ZIP is located, simply open the demo link in the browser. For example, if the Blender version of the Scooter demo located here:
The corresponding ZIP archive for that demo is available under:
Electron binaries
Follow this guide.
See Also
