Known Verge3D Limitations
This page describes common Verge3D limitations and bugs and provides possible workarounds.
General limitations
Camera Scaling
HiDPI Compositing Limitations
Export multiple animation clips for the same object
Deep Collection Instancing
Material animation
Physics
Postprocessing
Rotation animation
Textures
XRef Objects
Verge3D for Maya limitations
View Transform
Always switch to sRGB gamma view transform to get consistent results. See here for more info.
