Common gotchas with Verge3D
Revision as of 17:57, 7 February 2026 by Alexander (talk | contribs)
Huge shadow maps
Swapping object on click
Essentially, App Manager uses background web server process attached to the particular user. Even after you perform a log out, this process stays as is and will prevent another App Manager session to be started. This might cause real confusion and various unpredictable bugs. Always stop App Manager (via About dialog) before you switch the user.
