verge3d-blender-4.9.2.exe /S
The Verge3D's .xz distribution is intended to be installed on Linux/ChromeOS. Still, you can unpack it and use on macOS / Windows as well (basically .xz is a portable version of Verge3D).
python3 setupAddon.py
python3 install.py
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
Host TCP Port Notes
See Also
