verge3d-blender-4.9.2.exe /S
python3 setupAddon.py
python3 install.py
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
| Host | Port | Notes |
| www.soft8soft.com | 443 | Downloads, Forums, online version of User Manual and Developer Reference |
| cdn.soft8soft.com | 443 | Verge3D Asset Store, Verge3D Network CDN |
See Also
