Revision as of 18:31, 14 July 2025 by Alexander (talk | contribs)
verge3d-blender-4.9.2.exe /S
Using Linux version on Windows/macOS
python3 setupAddon.py
python3 install.py
To active Verge3D via command line, send the POST request to the App Manager server.
Verge3D for 3ds Max:
Verge3D for Maya:
See Also
