Aggressive Optimizations
- Use smaller shadow maps (see here why)
- Use just one light that casts shadows
- Use Basic or Bilinear shadow filtering instead of PCF / ESM shadows (check out this info)
- Do not cast shadows from the point or area lights. They require 6 time more draw calls.
Disable post-processing
Disable HDR rendering
Get rid of light probes
OR:
Set IBL cubemap size to 256
No hardcore anti-aliasing
The instructions are here.
Emission shading only
