Known Verge3D Limitations
Camera Scaling
Deep Collection Instancing (Blender)
HiDPI Compositing Limitations
If you try to run multiple Verge3D flavors, e.g Verge3D for Blender along with Verge3D for 3ds Max, only the first one will execute the App Manager server. This means, when you create a new app, it will be created inside the distribution which is connected to the first modelling suite you run. Also, Sneak Peak feature will work only inside the first suite.
One possible workaround would be unloading the packge you don't need to use. Alternativelym stick to Verge3D Ultimate, especially if you need to mix assets from different modelling suites inside the same application.
