Pipeline #2 — using intermediate modelling software
Verge3D offers an outstanding level of integration with Blender, 3ds Max, and Maya. It allows you to setup all the materials/lighting/cameras/animations using either of those tools and quickly preview in the web environment. This method is more robust even it requires transferring your 3dm asset into one of the said modelling software.
To transfer your models from Rhino to Blender you can use the OBJ format, while for 3ds Max / Maya the FBX format would be a more straightforward approach.
Got questions?
