Pipeline #2 — using intermediate modelling software
Verge3D offers an outstanding level of integration with Blender, 3ds Max, and Maya. It allows you to setup all the materials/lighting/cameras/animations using either of those tools and quickly preview in the web environment. This method is more robust even it requires transferring your 3dm asset into one of the said modelling software.
To transfer your models from Rhino to Blender you can use the OBJ format, while for 3ds Max / Maya the FBX format would be a more straightforward approach.
In case you are not familiar with these modelling software tools, it's worth spending some time to learn one of them. First, Verge3D does not require you to be a guru in polygonal 3D modelling and second, contrary to pure glTF-based approach, you will get really powerful tools at your disposal. For example, there are plenty of material libraries optimized for interactive browser-based visualization, including packs aimed at the typical Rhino user: machinery and jewelry.
Got questions?
