Starting from version 8, Rhino does support exporting to glTF 2.0 format natively. Simply use File > Export Selected or Save As, then choose glTF Text File (*.gltf). After export is done, use the Verge3D toolkit to render glTF 2.0 in the browser (it does not matter what kind of Verge3D you choose).
When creating a new project using Verge3D, select Blank Scene. This way your project folder won't be cluttered with assets you don't really need.
Good part with this approach is that the camera controls are setup automatically. However lighting is a different story. Make sure you load an environment map and/or add a light source so that your model is visible.
Pipeline #2 — using intermediate modelling software
Got questions?
