Revision as of 06:28, 4 March 2026 by Alexander (talk | contribs)
Starting from version 8, Rhino does support exporting to glTF 2.0 format natively. Simply use File > Export Selected or Save As, then choose glTF Text File (*.gltf). After export is done, use the Verge3D toolkit to render glTF 2.0 in the browser. Camera controls are setup automatically. Make sure you load an environment map and/or add a light source so that your model is visible.
Got questions
