Common gotchas with Verge3D
Huge shadow maps
Swapping object on click
Inconsistent colors when using Alpha Hashed (Coverage) transparency
There is a known inconsistency when dealing with alpha hashed transparency. During rendering the browser mixes-in the background color from the <canvas> element even if the scene background is explicitly set to be non-transparent. Use the following puzzle to make the alpha hashed transparency work properly:
