Common gotchas with Verge3D
Huge shadow maps
Swapping object on click
The exec script puzzle won't work for custom CSS code, since CSS is not a scripting language. Basically, the following puzzle will fail with syntax error:
Instead you should create a new <style> element and insert you custom CSS as its "textContent" property:
