verge3d-blender-4.9.2.exe /S
Using Linux version on Windows/macOS
Registering Blender extension manually
python3 setupAddon.py
Registering 3ds Max plugin manually
On Windows, go to the python\maxPluing\setup inside the Verge3D installation folder, then run:
python3 install.py
See Also
