Aggressive Optimizations
Revision as of 06:36, 25 April 2025 by Alexander (talk | contribs)
Cut off features slowing you down!
  • Use smaller shadow maps (see here why)
  • Use just one light that casts shadows
  • Use Basic or Bilinear shadow filtering instead of PCF (Poisson Disk) / ESM shadow (check out this info)
  • Never cast shadows from the point lights!
Disable post-processing
Disable HDR rendering
Get rid of light probes
  • Keep IBL map but remove all light sources. For better performance, you might also switch IBL mode to "Light Probe + Cubemap".
OR:
Set IBL cubemap size to 256
No hardcore anti-aliasing
The instructions are here.
Emission shading only
