Known Verge3D Limitations
Camera Scaling
Deep Collection Instancing (Blender)
HiDPI Compositing Limitations
A possible workaround would be unloading the package you don't need to use. Alternatively stick to Verge3D Ultimate, especially if mix assets from different modelling suites inside the same application.
