Rhinoceros (Rhino) is a popular CAD software used for product/industrial design (automotive, jewelry etc.) and architecture. In this article you'll find how to use this program to create interactive 3D web visualizations that work in the browser.
Starting from version 8, Rhino does support exporting to glTF 2.0 format natively. Simply use File > Export Selected or Save As, then choose glTF Text File (*.gltf). After export is done, use the Verge3D toolkit to render glTF 2.0 in the browser. Camera controls are setup automatically. Make sure you load an environment map and/or add a light source so that your model is visible.
Pipeline #2 — using intermediate modelling software
